Jims Web Site
Date:  10-20-2008
Number of Hours:  2.50
Brief Description:  Landing light wiring
Mounted the harness for the lianding light. I installed a nutplate for an Adel clamp and ran the wire from the harness up throught the spar, made a loop and crimped knife connectors to the light wires. I will heat shrink this connection later. There is enought wire that when the bulb burns out I will be able to pull the light out through the leading edge to disconnect the wires.
