Now that I have most of the wing completed I need to plan the electrical harness. This wing will not have the autopilot but does have the heated pitot. I strung 4 wires through the wing. Position lights, strobe power, landing light, and pitot heater. The pitot tube ends up being a permament installation. This goes against my personal 'serviceability' goals whenever I try to design things. The tube gets flaired at each end and recieves the sleeve and nut, so the tube will not be able to be replaced without cutting the nut and flare off the end. I guess that I have resigned myself to the fact that there will probably never be a reason to remove/replace this tube anyway so it might as well be permament.
