Assemble the fuel tank skin to the ribs. Again, this took longer than I expected because of the difficulty of getting the skin and ribs to go together. Assembled the stiffiners. Mounted the brackets to the rear baffle and mounted the rear baffle to the tank skin. Mounted the whole mess onto the wing and drilled the bracket mounting holes and the splice plate. It's time to check the straightness of the wing. Hopefully it will all be good.
