Drill, debur, prime, rivet aileron brackets. As you can see there are three brackets showing. There are two brackets on each wing. So I have assembled both the left and right wing brackets. The missing one is mocked up onto the wing. I am building the left parts whenever I can. I hope that when I finally get to do the other wing it will go much faster since I have done a lot of the fabrication ahead of time.
