Mixed up an extra large batch of Proseal to mount the rear tank baffle. The hardest part was pop riveting the 'z' brackets to the back. I had trouble with my rivet gun and about every third rivet I had to disassemble the rivet gun to retrieve the shaft which had either disappeared into the jaws or was jambed so tightly that it would not release. I've had this tool for about 40 years and it has never given me any trouble, old age I guess. Riveted the long rows on the top and bottom, this went very quickly. took the cover off to see in the tank and it looks like I should have a good seal. I will test later for leaks. It feels good to be at this point. The tank is finnished! Now I can go back to the wings.
