Brief Description: Rivet rear spar, installed center bearing
Squeeze all the rear spar rivets. Install rear center bearing to rear spar. torque nuts to 25in/lbs. Inspect all work, compare to plans. Finished!!!! One part down!!
Cleaned the shop in preparation to moving onto the next part. I made a rack to hold the HS up in the ceiling. Due to my space constraints I must be carefull with how I store the sub-assemblies until I have more built.
