Mock up the control column. Ream bushings to fit. I found that I had to shorten the bushings quite a bit. So short that I needed to grind the edges of the control yokes themselves. Then I fould a note that said to grind the yoke. Once again, it all seems to be there you just have to look. Sorted the hardware and adjusted the parallel push rod. Should be close. Wrap up all the parts and put the hardware in a tin for the future.
