Both trailing edge wedges are needed to set the drill location at the trailing edge. The left flap had to be stopped short of completion untill the right flap is past the trailing edge drilling.
So today I assembled the right flap. Nose ribs to spar. Bottom skin to spar. Drilled the holes in the table and oversized the holes to 5/8".
