Jims Web Site
Date: 5-20-2008
Number of Hours: 2.00
Brief Description: more ribs
Glued and riveted two more ribs tonight. Same as before. Clean, glue, rivet, clean, clean somemore, determine if everything is clean, find more places that were touched and clean those spots, think you got it all and find more, clean the tools, clean the colecos, clean the skin again, clean your fingers. How did it get on my elbow? Clean that. Did I mention that this stuff is messy. It's worse than any booger stuck to the end of your finger. Just getting this stuff out of the can requires a certan amount of finess. I didn't mention on yesterdays entry that I have a method worked out. I put a piece of alum foil on the end of the scale and glop onto that. I can mix with a popsicle stick, spead with a stick and smooth with a finger. And the best part is, since this is so nasty to work with I get to pick the finger to use. Use your imagination.
