Installed bottom skins and match drilled. The instructions indicated that a tool in the form of a stick with a hook or dowel on the end would help to push or pull the ribs into place. All of the ribs lined up just fine. I did take the time to make sure that each rib was fluted properly untill it was straight. The straight ribs matched up to the holes without any trouble. Sure looks like a wing now. But, I do not get my hopes up yet because I know that it still has to come apart again. There is still a lot of debur and dimple in my future.
