Brief Description: Rivet skin to main ribs, mount rear spar to HS
Rivet skin to main ribs. Coleco rear spar to HS.
Once again it doesn't look like much of a description but it takes quite a while to rivet. I also reviewed to plans to make sure that I was really this close to being done with this part. If there are any rivets not up to par up to the point of installing the rear spar they must be replaced now. After the rear spar is on it must be removed to gain access to the back side to buck the rivet. I have done all the proper steps and all looks good so I colecoed the rear spar into place.
