Installed the push rods for the elevators. The front push rod would not go in without some jocking around. Seems it would not slide in from the rear and could not go in from the front. Should have built the plane around this part. After much thought, I removed the rod ends which made the rod shorter, not short enough, but shorter. With the right amount of persuasion, slight bending of a bulkhead and a couple of prayers I finally got it in place. I hope I never need to remove this rod.
