Brief Description: Drill for pitot line through rib and fuselage
With the wing mounted to the fuselage I drilled through both the fuse and the first wing rib. I wanted to be sure I had good alighnment for the pitot line. I didn't realize just how tight the space was between the rib and fuse skin. Fingers barely fit and would be difficult to work in the slot. That influenced where the line would need to go. I originally had planned a little further out toward the tail but as it is I could reach through the aileron hole and get the line started if needed.
