Fabricate the control cover. I couldn't vision this part when it came along in the instructions so I moved onto the flap motor assembly. Once that was done the space between the flap assy and the control column was clear. Fabricating this piece became easy. The drawings are allways so helpful. Make the pieces as per the plans and it all fits. I should know by now that if I build it to spec it will fit. Still that fear of the unknown, "How does this fit? What if I do it and something else gets in the way?" rears it's ugly head and I question the instructions.
