Cut holes in the seat back plate. Assemble the seat parts to mock up the completed seat. I put the assembly into the fuselage and felt that the hinge was not in the proper position. It seems to want to be a little more to one side or the other. Maybe I will need to redo the hinges to fit better. I made the seat back as per the plans. So far everything else has worked out even though at the time it didn't seem correct. I think I will not rivet the bottom hinge until I get the flap motor and console installed. Rivet the seat together all except the bottom row.
Begin the fabrication of the second seat side rails.
