Fabricated and drilled the F695 firewall gussets. Rivet gussets. Rivet the crotch strap holders. Decided that I need to go ahead and order the seatbelts. The hole for the crotch strap mounting has not been final drilled. I have seen conflicting information on the correct size of the bolts used. With one side monted I can still drill and debur the mounting holes as necessary. Begin fab of the seat belt shoulder harness mounts.
