Brief Description: Elevator and counter balance arms
Stiffeners were cut and fitted to skins. No big deal, but it took too long. I also tried a new way of dimpling. I ended up clamping the tool to make it stand up vertically. This give me complete freedom to work around the tool without any having to handle the tool The work was then fitted around the tool and the surface dimpled. Also I worked on the counter balance sections. Everything was a tight fit, but after working the metal everything fitted very well. They designed all of the holes to fit well. Riveting the easy way. Counter balance arms Clecoed arms
