Clecoed and match drilled rear spar assembly. (HS 609, HS 603,) Match drilled brackets HS 411, 412, 413 to rear spar. Match drilled, deburred, rivetted VA-146 bearing in between HS 411 brackets. Moved on to front spar HS 702 and drilled the relief holes centered on the bend line instead of placing the edge of the hole on the bend line. Ordered new parts for HS 702 as well as HS 714 and HS 710. I cut and shaped the edged of 710, 714 but then worried about the edge distance being a bit too small so that is the reason for ordering new parts.
