Today I re-made the second step support, mounted and reinforced it. Much better than the prior effort. I'm essentially out of epoxy, with more not to be here till Tuesday, but I did have enough to pot in the last support. While things were curing, I fitted the engine mount reinforcement I got from Dave McNight. It took a bit of minor trimming of the strut bearing block mounts to get the box to fit close enough to weld, and this took quite a bit of time, but it now looks good.
