The more I looked at yesterday's work, the less I liked it. The second step support just didn't line up with the step properly. I believe that it would have been fine, as after cure the strength was impressive. Nevertheless, I decided to take out yesterday's work and start over. I shortened the support and trimmed it to align more properly with the fattest part of the step sleeve. Just potted it in today, and will add two bid support tomorrow if I don't run out of expoxly first. Also today I placed two Bowden clamps to hold the heater control cables. More work on that later.
Also, Dave McNight sent me an extra engine mount support, which goes between the strut mounts. It does not fit perfectly, but I should be able to make it fit. I'm going to take this task very slowly.
