Jim's Web Site
Date:  1-18-2017
Number of Hours:  2.50
I finally got the B-nut for the parking brake valve arm today, and was able to mount the cable mounting bracket to the fuselage. Also trimmed and cleaned out the bolt holes for the hatrack flange. With that extra two bid, the flange is a lot more stout, and I'm sure on its own will provide substantial strength to the rear quarter of the fuselage. Finally, I received the right size bolts to mount the flap actuating arm to the torque tube halves, and installed them tomporarily to check for fit.
