The last few days have been a bit tedious, with progress to be sure, but little to show. I learned that the flaring tool I was using for the brake lines was a 45 degree, not the required 37 degree. So I cut the improper flares off and re-flared with the right tool. There was enough wiggle room with the brake lines to enable this with minor adjustment. I've also potted in a couple of studs to hold adel clamps for the brake lines. Also, I've made the mount for the fuel selector. Also, I've made the cable connections for the seat track connection. With all this going on, I temporarily mounted the pilot seat and the instrument panel, to check for relationships between the seat and the rudder pedals, panel and control stick. In addition to that, it became obvious that the two seats are too close together if I use the pre-installed mounting reinforcements. I'll have to add more mounts to solve this problem.
