The last two days I've reinforced the rear bottom seat supports and the rear seat back flanges. Because the aft reinforcement calls for six bid, and its nearly vertical, I decided to apply it in two bid layers, allowing about 1.5 hours between layups. That way the first two layups were really tacky before the next layers were applied. This worked pretty well. A few air bubbles, but not many at all. I topped the last layers with peel ply, to soak up excess epoxy and to help the edges lay down better.
