In order to be able to set the rear seat back supports, I needed to fit temporarily the upper fuselage. That went pretty well, and I now have the templates necessary for fabricating the supports. I also finally fitted the elevator push rod cover supports. Also spent quite a bit of time trying to come up with a final design for the rear seat supports and lower rear set back. Lots of options.
