Jim's Web Site
Date:  2-27-2016
Number of Hours:  8.00
Yesterday more glazing and sanding, and more of that today. But finally I was able today to test spraying the WLS primer on the wheel pants. It actually went much better than I expected. I did it outside, and used an OV respirator, which worked very well. I couldn't even smell the MEK. Cleanup was not a big deal at all. I sprayed both pants with about four ounces of WLS. Tomorrow the plan is to spray another coat on the belly. I still need to sand it a bit, and have been helping the slow cure along with a couple of halogen lamps. The primer is now powdering up well with a dry sand using 80 grit. Still have some more to go,
