The primer has still not cured sufficiently to prevent sandpaper clogging, either wet or dry. So today I continued on the right leg fairing, and did a bit on the left inspection panel. There I had to add a small blister to clear the leg bolt. Earlier I had formed a carbon fiber blister, and last night bonded it to the panel. Today is covered the blister with micro, which tomorrow I will smooth out and cover with one bid, later to be followed with a thin micro coat. I also spent some time sanding last night's micro on the right leg fairing, added a bit of glazing afterwards, and sanded that down as well. All that's left on the underside of that fairing is to fix a few pinholes and prime.
