I'm at a bit of an impasse because the manual references Blueprint 3501, which I don't have, and neither does Lancair. Justin has posted on the forum for help, but no joy so far. Problem is that I don't know what I don't know, and I need to know the angular relationship between the inboard flap actuator and the outboard actuators on the torque tubes. This is so I can drill the torque tubes to connect the coupler.
I was able to finish mounting the main gear receptacles, after getting from Lancair some more bolts. It ultimately took three lengths of 3/8 inch flat head machine screws to get the proper number of threads protruding from the lock nuts, but they look good now. I got them all torqued to proper specs and applied torque seal. I'll touch up the paint later.
