Jim's Web Site
Date:  11-25-2015
Number of Hours:  5.00
The last few days I've been setting up to set the toe in angle on the main gear. This involves a lot of measuring, leveling and jig making. I also decided to use Loctite 680 retaining compound to fix the axle bracket to the leg while drilling out the bolt holes. Tonight I got it all set up, went through a dry run, then set both wheels in place with Loctite. It's supposed to cure for 24 hours, so I'll see tomorrow how it works.
Right main gear set up, from aft
Right main gear from forward
Left main gear in jig
