There are 32 bolts that mount the two main gear receptacles. Today I finished drilling out the holes for all of these bolts, except for one, the aft lower outboard bolt. The first thirty went pretty easily, but the two aft lower outboard bolts require removing some existing material from the inside of the fuselage to allow for the right angle drill. One more left, then it's drilling out the 1/4 inch reinforcing plates.
