This week I've begun installng the main gear. Took me quite a while to get the pre-drilled holes in the gear legs and gear receptacle cleaned up sufficiently to allow the attaching bolts to pass through. Then I designed and made cradles to hold the receptacle/gear leg assembly in place, at the correct angle, to allow attaching to the spar box. Next is fine adjustment and adding expoxy/flox.
