I've pretty much got the wings set for finishing so now it's time to return to the fuselage. To fit the spar box halves to the wing and the fuselage, and in accord with the manual, I prepared two templates, one for each spar box half. To do this, I first cut out a template from cardboard, then transferred that to 1/8 inch plywood. Cutting that a bit oversized, I then fitted the wood template to the fuselage with multiple fittings and sandings. Of course I can't determine the location of the wing bolts yet, as that will have to wait until the wings are insterted into the fuselage and bolted together.
