I've decided that the slight concavity on the top of the flaps needs to go. It's not much, but it will be noticeable at the gaps between the flaps and the ailerons and the fuselage fairing. So tonight I laid down micro on the right flap. I've learned to over do it a bit on the micro, which is fairly easily sanded off, but problematic to add more.
