Applied sealer to all the fuel bays today. I'm getting pretty close to being done with the wing construction, so I'm going have to assemble the masses for the second and last wing closing party. In the meantime, I'm checking the manual checklist to make sure no steps are missed, including mounting the bellcrank and idler arm, including torqueing the bolts and marking with torque seal. I'll also re-check for sufficient clearance between the ribs, spar and aileron rods. But I'm pretty sure that it's done.
