I spent the first couple of available hours today trimming up the last few capstrips, including removing excess bid from around some joints between ribs and the main spar, being extra careful in the fuel bays. After that, I placed the fuel probe in, floxing in the delrin grommmets adn the aluminum threaded mount. Then I placed 2 and 3 bid around the mounting block on the inboard rib. Finally, I drilled the holes in the inboard rib for the fuel inlet and the fuel return line.
