Finally finished reinforcing the ribs and shear webs tonight. Last thing to do was to reinforce the aft shear webs. In doing that, I used some peel ply to help the reinforcement follow and adhere to the contour of the upper wing skin, where it transitions from the core to the skin. We'll see how that works tomorrow.
While I was waiting for the micro fillets to cure before applying the bid, I placed all bolts, washers and lock nuts required to mount the wing attach bracket. Next I'll torque to final specs and begin sealing the bolts from the inside.
