Jim's Web Site
Date:  5-26-2014
Had to work half of this Memorial Day. But after work I did get to do some productive work on the ES. Doesn't seem like much, but I got the lower edge of the wing tip pretty well even with the wing, and microed in the transition. Also, I reinforced the NACA scoop for the fuel vent, and blended the scoop with the wing tip. Finally, I began finishing the outboard end of the aileron, but inserting foam, and 2-bid.
Lower wing tip, with transition microed in
Outboard end of aileron
