Got home late from work tonight, so not a whole lot of time. I decided to add micro to the bottom side of the aileron, to correct the slight concavity of the chord-wise surface. I know there is a question of whether the concavity is a design element, but Lancair says to fill it, leaving a flat surface, so that's what I'll do. There is a bit of a weight penalty, but not a lot. The total weight gain will be about six ounces for the micro, and whatever is required for the lead on the front to counterbalance that added weight. Most of tonight's application of micro will be reduced to dust tomorrow.
