This evening I reinforced each of the fuel probe bushings, and then drilled the holes for the fuel return. The location for the return tube overlaps the five bid reinforcement on the inboard rib by about half, which left an uneven mounting surface. So to remedy this issue, I formed a pad of 50/50 flox micro. Tomorrow I'll sand the surface even and mount the tube.
