Reinforced the bellcrank mounting area on the BL 145.5 rib today with 8 bid. Next I assembled the aileron idler, making 1/4 inch spacers for the mounts as directed. Finally, I formed a micro/flox pad on the outboard side of the BL 75 rib where the idler mounts, as the rib in that spot is not flat, due to the capstrip and rib to skin reinforcing. This is accomplished by placing a micro/flox mix on the rib in the mounting area, and clamping a steel plate on top to make a flat mounting surface. I'll remove the steel plate tomorrow.
BL 145.5 rib reinforced with 8 bid for bellcrank mount
Aileron idler assembled and mocked up
BL 75 micro/flox ilder mounting pad being formed by steel plate
