Last night I completed the task of cutting the lower skin for the flap hinges. Two of the cuts are fine, but one is not pretty. I'll have to dress up the gap later. After that, I cut two access holes for the flap hinge bolts, and placed four bid from the inside to mount the nutplates. All that went pretty well, until I figured out that the flange decreased the opening size more than I expected.
So today I drilled the holes for the securing screws, and learned that, indeed, the access hole is now a real tight fit for my hand. I think it will be ok, but only because accessing the hinge mount bolts probably won't be a frequent event.
