Jim's Web Site
Date:  9-22-2013
Number of Hours:  2.30
Not much time this week, and USPS delivered the bolts from Aircraft Spruce to the wrong address, and other obligations, blah, blah, blah. Nevertheless, I did make progress. I was able to install all proper length bolts, washers and nyloc nuts necessary to fix the wing attachment bracket to the forward shear web. After that, I prepared the mandated 1/4 inch foam piece to fit over the attachment bolts. Then, per instructions, I surrounded the bolt heads with epoxy/flox, bonded the foam over the bolts, then covered the whole mess with 2 bid. All this was necessary because the bolts are inside the fuel bays. Here's hoping for the best.
Wing attachment bracket bolts
Foam for bolts
Foam for bolts
Bolts and foam covered with2 bid
