Jim's Web Site
Date: 9-5-2013
Number of Hours: 2.30
I'm not sure why it took me so long to reinforce these two ribs, but it sure did. I didn't time it, but I believe that it took a long time to prep the joints for bonding. As with painting, preparation is a major part of the job, so I'm trying to be thorough.
I did measure the effectiveness of the peel ply, which, by the way, is a real pain to remove. On approximately three feet of peel ply, the epoxy absorbed amounted to .05 ounces. Not much at all. Today I compared the peel ply to the suggested paper towel method, and found that a comparable amount of paper towel strips absorbed .15 ounces, about three times more than peel ply. That's a real rough expirement, and would have to be duplicated to verify. But I've decided to forego the peel ply on interior surfaces, and just use paper towels.
Anyway, tonight I reinforced the BL 75 nose rib, which is the mounting rib for the aileron idler. Also reinforced the BL 54.5 middle rib.
BL75 nose rib, reinforced
BL 54.5 middle rib, reinforced
BL 54.5 middle rib, looding outboard
