Jim's Web Site
Date:  8-28-2013
Number of Hours:  1.00
A bit easier today. I decided that attempting to transition one continual piece of layup from horizontal to vertical is very dicey, so I decided to join the vertical and horizontal elements of reinforcement by overlapping two separate pieces. Also, I decided to let the layups cure for a few minutes to give them a bit more resistance to ply separation during the application process. Also, I decided to make my bid strips as near as reasonably possible to the finished width, and forget about mathematical precision on the width. In prior layups, if I needed a two inch strip, I would cut out about four inches, make the epoxy sandwich, and cut out the finished strip from the larger layup. That, I determined was a waste of time, cloth and epoxy. So the final applications now are not as pretty and uniform, but they are ultimately within specs.
BL 25.5 inboard rib reinforcement
BL 140.2 inboard aft rib reinforcement
