Jim's Web Site
Date: 8-24-2013
Number of Hours: 3.50
Fillets on the outboard aft shear web only took a bit, then I started reinforcing some ribs. Since it had been some time since I'd done layups, I started with some easy ones, the BL 54, 97 and 120 aft ribs. Only one required a 7 bid layup. I also spent some time labeling the bid specs for the various ribs, so I won't have to look the specs up each time I reinforce a rib. Also spent some time cutting out bid tapes. Quite exciting, let me tell you. A couple of the ribs are still too green to trim, so I'll do that before bedtime tonight. Anyway, some progress, to be sure.
Aft shear webs, with proper micro radii
BL 75 aft rib, reinforced
BL 120 rib reinforced with 7 bid
