I thought that it would be easier to just pot in the ribs before forming the micro radii at the joints. Maybe or maybe not. Tonight I started forming the radii, and it was a bit tedious. I got the fillets formed on the inboard sections of the fuel compartments and associated forward ribs. But it took over an hour to sand, prep and form. But it may be easier on the less complicated joints more outboard. Doesn't matter much, cause I've got to do it. Forming the fillets seems easy if you look at the manual, but let me tell you, it ain't. This is especially true on the complex joints.
