Today I potted in all of the remaining ribs. Next are the trailing edge shear webs. After that, reinforcing all the ribs begins.
The heater box with only one 40 watt bulb keeps the temp at 80 degrees. This seems to be pretty good, and should keep the resin from crystalizing. Not so hot as to make the epoxy cure too fast, however.
Sometimes I think that I am the only one in the world working on a slow build Lancair.
