Hopefully things will begin to start rolling now. This evening I prepared to reinforce the flap and alieron hing mounting areas on the appropriate trailing edge ribs. This includes removing part of the core and one side of each rib, sanding and prepping for 6 bid reinforcement. I also cut out cloth for the reinforcment. After that, I began to clean out the epoxy pump, which I have not used for six months. Predictably, the resin side had gummed up, but I got a good start on getting it ready for use. Tomorrow I should be ready to start layups.
