This afternoon I made six brackets to hold the ribs in place during the wing skin fitting and rib bonding process. That took a while. I'll add pictures tomorrow. After that, I spent some more time fitting the BL120 forward rib. The best way I've found so far is to light the inside of the wing from the outboard side, and sight the rib from the inboard side, thus having the rib backlit. What takes the time is raising the lower skin after taking off the BL 138 top cradle and removing the clecoes. What does help is marking the rib with lines and numbers, so that I can tell where to trim.
