The ribs closer to the wing tip are quite a bit easier to fit than those more inboard. So today I was able to get three ribs fitted. Next I'll cut out the most outboard ribs, which are made from 2 bid instead of 3 bid. For a break, I took a bit of time to transfer the wing attach bracket from the rear to the front of the shear web. Naturally, only a few of the eleven bolt holes lined up, so I did have to ream out the holes in the spar a bit to get the bolts to fit. I'm not pleased with that, but there was really no option, and there's still lots of reinforcement left to build to ensure the stability of the wing attach bracket.
