After a bit of fine tuning of the stringers' height relative to the cradles, Cathy helped me hoist the left wing onto the cradles. As forecast by the manual, the skins did not quite fit the cradles at the leading and trailing edges. The cure is to screw down the edges, and weight the skins elsewhere. Then I'm supposed to add fillets of Bondo at the skin/cradle intersections. I placed the screws and weights tonight, and that did bring the skins into proper position relative to the cradles. Didn't have the time today to place th Bondo, but I did spend quite a bit of time removing peelply from the inside of the upper skin. That's not my favorite job. Very slow and tedious.
